| Literati914 |
Dec 12 2025, 03:27 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,174 Joined: 16-November 06 From: Dallas, TX Member No.: 7,222 Region Association: Southwest Region |
Anyone know the lengths needed for modern hood struts/shocks for the front ? I would assume that the lbs weight per, spec would be about the same as the rear that I got since the hoods probably weight about the same (I got 60lbs for the rear iirc). But the length is a critical detail that I’m unsure of.
Also wondering about mount placement at the front. Since my rear set have the metal ball joint, I’d like to use the same in the front .. so I was thinking that maybe the stock spring hook multi-mount tab could be utilized with just a simple ball end bolt through it, in the correct size. Anyone done that? General pics of a front set up would be helpful, thanks. Here’s my rear set up: Attached thumbnail(s) |
| dtmehall |
Dec 12 2025, 05:32 PM
Member ![]() ![]() Group: Members Posts: 224 Joined: 21-December 23 From: Farmington Hills, Michigan Member No.: 27,808 Region Association: Upper MidWest |
a little off topic.
where can you get the shocks for the rear hood these days? |
| Nate W |
Dec 14 2025, 09:28 AM
Member ![]() ![]() Group: Members Posts: 99 Joined: 23-February 21 From: Oceanside, Ca Member No.: 25,250 Region Association: Southern California
The ones I have are 12 3/4” when extended (frunk open) and about 9 1/4” compressed
Mine are mounted to the part where the springs attach. You might want to make a bracket to use there, it kind and f bends the mounting hooks , possibly cracking the paint. On the frunk lid side they are mounted to one of the hinge bolts ( the one closest to the windshield |
Lo-Fi Version | Time is now: 16th December 2025 - 09:40 PM |
| All rights reserved 914World.com © since 2002 |
