Electrical issues - fuses?, Gauges and turn signals not working |
sarivers2001 |
May 9 2024, 06:09 PM
Member Group: Members Posts: 56 Joined: 16-August 23 From: California Member No.: 27,527 Region Association: Northern California |
Good afternoon everyone! I have a question for the group.
My 1974 914 2.0 was operating just fine when I dropped it off at an autobody shop for some rear quarter panel bodywork involving some repainting. I picked it up today and now none of the electrical gauges are working. While the speedometer and odometer are working (I believe they are only mechanical), the tach stays at zero. The red generator light turns on shortly after starting (but not immediately) and the fuel gauge and voltmeter in the center console flicker up and down when I apply the brakes. I suspect that one or more of my fuses got fried while the body work / painting was being done, or it may be a simple as somebody banging their knee against the fuse box. Any other thoughts or similar experiences out there? Many thanks, Steven |
sarivers2001 |
May 9 2024, 08:23 PM
Good afternoon everyone! I have a question for the group. My 1974 914 2.0 was operating just fine when I dropped it off at an autobody shop for some rear quarter panel bodywork involving some repainting. I picked it up today and now none of the electrical gauges are working. While the speedometer and odometer are working (I believe they are only mechanical), the tach stays at zero. The red generator light turns on shortly after starting (but not immediately) and the fuel gauge and voltmeter in the center console flicker up and down when I apply the brakes. I suspect that one or more of my fuses got fried while the body work / painting was being done, or it may be a simple as somebody banging their knee against the fuse box. Any other thoughts or similar experiences out there? Many thanks, Steven Follow up question: what are some recommended sources (stores? Internet sellers?) to buy original equipment style replacement fuses? Thanks again |
fiacra |
May 9 2024, 08:45 PM
Person.Woman.Man.Camera.TV Group: Members Posts: 330 Joined: 1-March 19 From: East Bay Region - California Member No.: 22,920 Region Association: Northern California |
Good afternoon everyone! I have a question for the group. My 1974 914 2.0 was operating just fine when I dropped it off at an autobody shop for some rear quarter panel bodywork involving some repainting. I picked it up today and now none of the electrical gauges are working. While the speedometer and odometer are working (I believe they are only mechanical), the tach stays at zero. The red generator light turns on shortly after starting (but not immediately) and the fuel gauge and voltmeter in the center console flicker up and down when I apply the brakes. I suspect that one or more of my fuses got fried while the body work / painting was being done, or it may be a simple as somebody banging their knee against the fuse box. Any other thoughts or similar experiences out there? Many thanks, Steven Follow up question: what are some recommended sources (stores? Internet sellers?) to buy original equipment style replacement fuses? Thanks again Multiple sources for the fuses, which are readily available. Any VW parts supplier (CIP1, Wolfsburg West, JBugs, etc...) will have them. I can get them at my local auto parts store and since you are also in Northern California it's likely you can as well. Given your problems started when someone worked on your car the first place I would check would be the area worked on. If you have a blown fuse (although you don't say if you checked) it blew for a reason. Certainly the wiring for the brakes is in proximity to the rear quarter panels. Run the wiring and look for any damage, detached grounds, shorts, etc. Did they paint over a ground and not clean the metal? Did they remove the rear tail lights? Check connections there. That's at least a good place to start. |
Ishley |
May 9 2024, 09:06 PM
Member Group: Members Posts: 96 Joined: 4-October 21 From: Clarendon Hills Il Member No.: 25,957 Region Association: Upper MidWest |
If you had work on the drivers side check the relay board and make sure all the plug in cables are seated properly. Also there is a ground behind that board that should be cleaned and make sure all the wires to it have a solid connection.
Dave_Darling |
May 9 2024, 09:59 PM
914 Idiot Group: Members Posts: 14,986 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
I believe that it's fuse #8 being popped that causes these symptoms.
I picked up some ceramic fuses at O'Reilly's in Sunnyvale, so you shouldn't have much trouble finding them. --DD |
NARP74 |
May 10 2024, 07:55 AM
Senior Member Group: Members Posts: 1,067 Joined: 29-July 20 From: Colorado, USA, Earth Member No.: 24,549 Region Association: Rocky Mountains |
I have a very similar post to this one. Check the tail light connections in the trunk. They are exposed, might be hard to see, gymnastics required. I had a connection shorted after it was hit by something I loaded in the trunk for a trip. Took out the same circuit every time I used the left turn signal.
Find a local bug shop or older German car shop. These fuses were used on more cars than I realized. I bought some online, time was not a big issue for me. |
FlacaProductions |
May 10 2024, 08:53 AM
Senior Member Group: Members Posts: 1,591 Joined: 24-November 17 From: LA Member No.: 21,628 Region Association: Southern California |
I'd second the checking of the tail light connections.
Here's a map: http://www.914world.com/bbs2/index.php?s=&...t&p=2720145 Fuses: https://www.amazon.com/dp/B07F2739HM/?colii...lv_ov_lig_dp_it |
dr914@autoatlanta.com |
May 10 2024, 09:50 AM
914 Guru Group: Members Posts: 7,866 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
fourth fuse from the right not making a good connection
Good afternoon everyone! I have a question for the group. My 1974 914 2.0 was operating just fine when I dropped it off at an autobody shop for some rear quarter panel bodywork involving some repainting. I picked it up today and now none of the electrical gauges are working. While the speedometer and odometer are working (I believe they are only mechanical), the tach stays at zero. The red generator light turns on shortly after starting (but not immediately) and the fuel gauge and voltmeter in the center console flicker up and down when I apply the brakes. I suspect that one or more of my fuses got fried while the body work / painting was being done, or it may be a simple as somebody banging their knee against the fuse box. Any other thoughts or similar experiences out there? Many thanks, Steven |
sarivers2001 |
May 12 2024, 07:13 PM
Many thanks to all for their advice and recommendations. The culprit was, in fact, the fuse that George and few others identified in the thread above. After taking a closer look at the fuse box and the condition of the other fuses, probably time to swap them all out for some new ones, and I definitely need a new fuse box cover!
Steven fourth fuse from the right not making a good connection Good afternoon everyone! I have a question for the group. My 1974 914 2.0 was operating just fine when I dropped it off at an autobody shop for some rear quarter panel bodywork involving some repainting. I picked it up today and now none of the electrical gauges are working. While the speedometer and odometer are working (I believe they are only mechanical), the tach stays at zero. The red generator light turns on shortly after starting (but not immediately) and the fuel gauge and voltmeter in the center console flicker up and down when I apply the brakes. I suspect that one or more of my fuses got fried while the body work / painting was being done, or it may be a simple as somebody banging their knee against the fuse box. Any other thoughts or similar experiences out there? Many thanks, Steven |
Lo-Fi Version | Time is now: 20th May 2024 - 07:19 AM |
