Factory 911 air cleaners, What fits what? |
mate914 |
May 6 2024, 04:29 PM
Matt Group: Members Posts: 749 Joined: 27-February 09 From: Eagles mere, PA Member No.: 10,102 Region Association: North East States |
I recently picked up a 911 mechanical fuel injection, air cleaner assembly . I was hoping I could use this with the carburetor Air cleaner base unit I already have. I was wrong once again. Can anyone point me in the right direction on how to make this set up work? I have no problem making custom clips to attach to. Has anybody modified a plastic air cleaner to work with Zenith air cleaner base mounts.
Matt |
mate914 |
May 6 2024, 04:31 PM
mb911 |
May 6 2024, 05:07 PM
914 Guru Group: Members Posts: 6,854 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
So you have an MFI top as you know and carb bases. I went through this a bunch of times and to be honest I even had to modify my steel one to clear everything but I don’t have to worry about that starting on fire like a plastic one just food for thought
rgalla9146 |
May 6 2024, 05:12 PM
Advanced Member Group: Members Posts: 4,559 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None |
Hey Matt
Don't modify anything yet. I have a plastic AF housing, Weber boats and a 2.2E MFI unit. Let me see if they cooperate. Rory |
rgalla9146 |
May 6 2024, 06:17 PM
Hey Matt Don't modify anything yet. I have a plastic AF housing, Weber boats and a 2.2E MFI unit. Let me see if they cooperate. Rory I just re-red your post and hope this helps MFI boats have different clips and a taller flange on the inner edge of the rubber seal If you trim the flange even with the top edge of the seal and change the clips I think you'll be in business. See the pics. Be carefull with the wire clips, there ar two versions. You'll need the larger ones Attached thumbnail(s) |
mb911 |
May 6 2024, 06:20 PM
Hey Matt Don't modify anything yet. I have a plastic AF housing, Weber boats and a 2.2E MFI unit. Let me see if they cooperate. Rory I just re-red your post and hope this helps MFI boats have different clips and a taller flange on the inner edge of the rubber seal If you trim the flange even with the top edge of the seal and change the clips I think you'll be in business. See the pics. Be carefull with the wire clips, there ar two versions. You'll need the larger ones I have done a dozen of these combos and I have never been able to get a good fit up with that mismatch setup |
rgalla9146 |
May 7 2024, 06:17 PM
Did MFI air filters have the enrichment spray parts ?
914 6 air filters did. Your snorkel is for a 911 Are the wing nuts plastic ? Fires in the plastic housings were caused by a faulty enrichment system, faulty carbs and faulty maintenance, not by the housing itself. Matt your housing is melted in the round openings for each stack. That's not unusual. Are the mating surfaces flat ? What carburators are you using ? Added pics of a plastic MFI housing. Attached thumbnail(s) |
rgalla9146 |
May 7 2024, 06:46 PM
And one more.
I hope this helps. And congratulations, that's a 914 6 housing. Attached thumbnail(s) |
mate914 |
May 8 2024, 05:03 AM
Tom1394racing |
May 8 2024, 07:58 AM
Member Group: Members Posts: 285 Joined: 25-August 07 From: CT Member No.: 8,039 Region Association: North East States |
I would suggest that you get an early steel airbox that is designed to work with the Zenith carbs.
Something like this one https://www.ebay.com/itm/194582624348?itmme...ABk9SR67J3YfrYw Post a WTB ad on Pelican or Early 911S Registry and see if anything turns up. |
930cabman |
May 8 2024, 09:01 AM
Advanced Member Group: Members Posts: 3,067 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States |
I am going through this now with a /6 conversion I have been for, well far too long. I actually found a steel air filter housing for cheap, but does not appear to be a bolt on
This might be the EZ button for my build : https://www.piercemanifolds.com/AIR_Filter_...p/pm-0314-0.htm Originality is not my #1 priority |
930cabman |
DP
mate914 |
May 8 2024, 02:34 PM
I would suggest that you get an early steel airbox that is designed to work with the Zenith carbs. Something like this one https://www.ebay.com/itm/194582624348?itmme...ABk9SR67J3YfrYw Post a WTB ad on Pelican or Early 911S Registry and see if anything turns up. Tom I am not using Zenith carbs I am using Webers. I was just using the Zenith base plates to see fitment. I might look into the metal top, but this is #597 factory 914-6. It will get factory parts as I can find and afford them. Matt |
mb911 |
May 8 2024, 03:51 PM
mb911 |
May 8 2024, 04:00 PM
nditiz1 |
May 8 2024, 04:24 PM
Senior Member Group: Members Posts: 1,188 Joined: 26-May 15 From: Mount Airy, Maryland Member No.: 18,763 Region Association: MidAtlantic Region |
Zenith and weber use the same bases
mb911 |
May 9 2024, 08:29 AM
zulu33 |
May 9 2024, 11:07 AM
Newbie Group: Members Posts: 9 Joined: 24-May 15 From: Germany Member No.: 18,755 Region Association: Germany |
Hi Matt,
it looks good. Maybe it's just put together wrong. You need the long clips. I use a plastic box with carburetor/ 2,2MFI base. Cheers Dirk |
rgalla9146 |
May 10 2024, 06:48 AM
Hey Matt What doesn't fit ? You have a 6 air filter, Zenith boats (same as Webers) and Weber carbs. When installing the stock air filter housing in the car it is a bit of a wiggle. Attaching the drain hose, the big vent hose and flipping a couple of the clips is annoying. Doesn't sound like any adaptation is necessary except for correct clips. |
Lo-Fi Version | Time is now: 20th May 2024 - 06:43 AM |
