Roof retexture |
Roof retexture |
garrettlee2 |
Nov 5 2016, 04:31 PM
Member Group: Members Posts: 158 Joined: 8-September 12 From: riverside ca Member No.: 14,901 Region Association: None |
Does anyone in southern California know of a good shop that could retexter a targa top or is there a good do it yourself method out there?
bdstone914 |
Nov 5 2016, 04:34 PM
bdstone914 Group: Members Posts: 4,522 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
Does anyone in southern California know of a good shop that could retexter a targa top or is there a good do it yourself method out there? There have been a couple of threads where members had their tops restored for about $300. When did you become a CW? (IMG:style_emoticons/default/poke.gif) |
garrettlee2 |
Nov 5 2016, 04:50 PM
Does anyone in southern California know of a good shop that could retexter a targa top or is there a good do it yourself method out there? There have been a couple of threads where members had their tops restored for about $300. When did you become a CW? (IMG:style_emoticons/default/poke.gif) ¿CW? No I swear it's not for me it's for...my friend. |
Localboy808 |
Nov 5 2016, 06:06 PM
Member Group: Members Posts: 185 Joined: 17-July 16 From: Palmdale, Ca Member No.: 20,194 Region Association: None |
Does anyone in southern California know of a good shop that could retexter a targa top or is there a good do it yourself method out there? There have been a couple of threads where members had their tops restored for about $300. When did you become a CW? (IMG:style_emoticons/default/poke.gif) ¿CW? No I swear it's not for me it's for...my friend. I did mine in wrinkle paint by VHT. I like the way it came out. |
914Sixer |
Nov 5 2016, 06:39 PM
914 Guru Group: Members Posts: 8,882 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
Looks pretty darn good (IMG:style_emoticons/default/biggrin.gif)
rgalla9146 |
Nov 5 2016, 06:47 PM
Advanced Member Group: Members Posts: 4,552 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None |
Buy another roof and repaint it ?
Localboy808 |
Nov 5 2016, 06:52 PM
Thanks! Took two full cans in case anyone is interested. Follow the instructions on the can. Basically the heavier the coats. The more wrinkles. Do your coats vertically. Horizontally. And diagonally to avoid streaks. |
garrettlee2 |
Nov 5 2016, 07:41 PM
Did you sand it smooth before you wrinkle painted it turned out great
Localboy808 |
Nov 5 2016, 09:28 PM
Did you sand it smooth before you wrinkle painted it turned out great No I didn't. It had most of the original texture still there. A few smooth spots. I used a scotch brite type pad on it just to break up the loose stuff. Then cleaned it really good. Then just shot the wrinkle paint. It looks great in person. And this stuff is made for high temperatures. Seems very tough. I'm not sure how it will hold up in the sun. Doubt it has any UV rating. But my car is garaged most of the time and it would be pretty easy to redo. AutoZone carries the paint if you want to give it a try. |
BeemerSteve |
Nov 5 2016, 09:54 PM
Member Group: Members Posts: 239 Joined: 2-September 15 From: Van Zandt, Wa Member No.: 19,123 Region Association: Pacific Northwest |
Local Rhino Lining will do mine for $150. Tuff stuff!
JawjaPorsche |
Nov 6 2016, 05:56 AM
Advanced Member Group: Members Posts: 3,463 Joined: 23-July 11 From: Clayton, Georgia Member No.: 13,351 Region Association: South East States |
Line-X did mine and looks awesome plus it is very durable.
Attached image(s) |
bdstone914 |
Nov 6 2016, 06:09 AM
I have at least six spare tops if you want one for practice.
Bruce |
914Sixer |
Nov 6 2016, 06:38 AM
Didn't the Line-X and Rhino Liner add a bunch of weight to the top since it is so heavy?
JawjaPorsche |
Nov 6 2016, 06:47 AM
Didn't the Line-X and Rhino Liner add a bunch of weight to the top since it is so heavy? I don't know about bunch but it is heavier. However, I do go to the gym so I didn't notice it. (IMG:style_emoticons/default/smile.gif) |
CptTripps |
:: Punch and Pie :: Group: Members Posts: 3,584 Joined: 26-December 04 From: Mentor, OH Member No.: 3,342 Region Association: Upper MidWest |
It really doesn't add that much weight. A 1-gal can of the stuff only weighs 5lb and that's for an entire truck bed. I'd hazard a guess that this only adds 1-2lb of weight.
McMark |
Nov 6 2016, 08:21 AM
914 Freak! Group: Retired Admin Posts: 20,179 Joined: 13-March 03 From: Grand Rapids, MI Member No.: 419 Region Association: None |
I researched the stock approach and was able to recreate it. I can also fix chipped corners. I can get closer to the original texture/pebbles than any other solution.
Attached image(s) |
Localboy808 |
Nov 6 2016, 07:32 PM
flat4guy |
Nov 6 2016, 07:35 PM
Member Group: Members Posts: 442 Joined: 10-October 16 From: nor cal Member No.: 20,484 Region Association: Northern California |
I like the way the VHT paint turned out, I think I might try this soon.
RoadGlue |
Nov 6 2016, 09:37 PM
Sonoma County Gear Head Group: Admin Posts: 2,033 Joined: 8-January 03 From: Santa Rosa, CA Member No.: 108 Region Association: Northern California |
patssle |
Nov 6 2016, 09:39 PM
Senior Member Group: Members Posts: 981 Joined: 28-August 09 From: Houston, TX Member No.: 10,741 Region Association: None |
I had Line-X done 5 or so years ago. Still looks great today!
Lo-Fi Version | Time is now: 16th May 2024 - 04:45 AM |
